668 Setup Question
ajayward
Hi All..
I've looked through the "Easier to Read" manual and I "don't see" an answer.
I've set up the 668 a few times, using different settings. From what I've observed, using county, city or zip code doesn't seem to make any (much) difference in what I receive. Is this correct or am I missing something?
Thanks for any wisdom!!!
Amanda
buddrousa
That is correct as those should be the same.
What Service types you have turned on will have an outcome on what you hear.
The downside to using only Zipcode, County, or City is you get groups or frequencies you care nothing about.
The upside of importing from the database is you get only the things you want to hear.
