br0adband
Found this in a junk bin earlier today, it appears to be powered through the line - I disassembled it and noted some circuitry inside the housing so I'm guessing it's an LNA to boost the rather low power signals from satellites as well as make up for the nearly 25 feet of cable attached to it). Perhaps the LNA might be re-purposed for something else, not sure if I can find any detailed information about it but I'm looking.
The actual radio unit connector is proprietary and not one I've ever seen before (apparently known as an SMB) so that's of no use but I could always just snip that off and add something else I suppose. Just noted with a Google search that adapters are available to convert it to more traditional connectors like F-type or others so that's a possibility as well.
Never been into satellite comms of any kind and my current hardware setup probably would be of much use either (simple RTL-based tuner sticks) but in the future I may be stepping up to something that could handle frequencies well above and beyond what these sticks are capable of.
I'll keep the antenna unless someone else asks me about it, can't really see much use but I figured if there was anyplace here at RR to ask about it this would be it. If it can be re-used for something else I'm game to modifying it but, as stated I'm not that much into the satellite side of things. Apparently XM worked in the 2.3 GHz range so I can't expect this will be of much use anywhere else.
Image of the particular one I have (as there seem to be quite a few variants):
Doesn't have a model or part number on the sticker, just says "XM Satellite Radio Antenna" with DELPHI and XM SKYFi logos.
Any hints or suggestions are most welcome, thanks.
