Go Back   The RadioReference.com Forums > Computer Aided Monitoring and Programming > Scanner Programming Software
Scanner Programming Software - This is the place to discuss third party scanner programming and control software.
Old 10-02-2008, 9:48 AM
Question Arc96 and Pro-96 Display
I have the Pro-96 and using Demo of Arc96 currently, what do I need to do to get it to show the Alpha Tag when it stops on an active channel? There is a Alpha Tag associated with every entry.
Currently it show something like this......
H400........+DG
VC 866.96250
Trunk CC
MOT: 07022
Version 0.96 build 2
I know there is a newer version, that is installed on another pc and still same issue.
On Configuration bottom right checked are "Extended Frequencies", "Digital AGC On"
Anybody know why it will not show the alpha tag on the display?
Old 10-03-2008, 7:25 AM
Butelsoftware's Avatar
Open the Configuration screen and untick 'Display ID Number'.
Gommert
www.butelsoftware.com
>>> Visit us at the 2018 Dayton Hamvention! SDS100 will be on demo! <<<
Dutch Design: best selling scanner software in the USA
US Sales: 1-800-SCANNER http://www.scannermaster.com/?Click=41054
Old 10-03-2008, 7:48 AM
Smile Resolved
Thank you for your time, talked to a friend last night who had the pro-96 for years and enlightened me to what closed mode is. :-)
Thanks again.
Old 10-03-2008, 9:36 AM
fmon's Avatar
Silent Key Jan. 14, 2012
Welcome to forum.
H400........+DG
VC 866.96250
Trunk CC
MOT: 07022 (annotate) This indicates you are scanning in Open Mode and this talkgroup is not programmed in any of the 5 subbanks.
MOT: 07022
This ID indicates you are scanning in Open Mode and this talkgroup ID with associated Alpha Tag is not programmed in any of the 5 subbanks.
You are subscribed to RadioReference so open ARC96, select Trunk button, find your system and import the control and alt controls on left side of dialog plus desired talkgroups from right side. This will import the Alpha Tags and they will be displayed on line 4 in either Open or Closed Mode.
Frank
RR Wiki Programming Shortcuts
Old 10-08-2008, 8:16 PM
hogwmn's Avatar
where you go to tell you how to set up your Arc96 on your computer got a pro2096 got a link or something ?
Old 10-08-2008, 8:30 PM
read the messages in this thread its BUTEL S/w the lnk in in the message
Old 10-09-2008, 7:26 AM
hogwmn's Avatar
Default Arc96 software
I got the Arc96 software only need to know how do I save the freq to download it on my scanner
Old 10-09-2008, 7:40 AM
If you want to save your frequencies to disc select File _ Save or use the Save button in the toolbar.
If you mean import from radioref use the 'Conv.' or 'Trunk' button in the toolbar to import directly from the database into ARC96.
Once the frequencies are imported hit the 'Send' button and that will send the data to the scanner.
Gommert
Old 10-09-2008, 8:13 AM
hogwmn's Avatar
Gommert
thank you that want i need to know very nice software like it alot
Old 10-09-2008, 7:14 PM
hogwmn's Avatar
Thumbs up
wooooo this software is so easy to work then other.........
Old 11-02-2010, 10:33 AM
Where do I find the frequencies so I can load them into my scanner from Arc 96?
Tags
arc96, display
