not sure about this, but it may never supported that feature. I looked on the wiki and it looks like there really isn't a lot of software that does support that scanner. might want to check out the regional forums to see is someone can send you the systems you want in a CSV file and you might be able to import them into the Butel software. you could also try the Yahoo! groups for that model.
EDIT: another thought, try FreeScan to get the data imported from RRDB, export to a CSV and then import (if you can) into the Butel software.
