echz
Hello! I am using Win500 v1.94 on a Windows7/x64 based system, and it's working great! One thing I have noticed, however, is that when scanning and recording all stations that are being heard, Win500 does not always record every conversation.
I have tried this with a Pro-106 and a Pro-197 and get probably 75% of all recordings. Occassionally once one frequency/talkgroup unkeys and the delay expires, sometimes the next transmission that comes in will not be logged and recorded by Win500. This may happen with the next one, two or possibly three transmissions before another one is recorded (I haven't been able to come up with a logical pattern of what's recorded when and what isn't).
Has anyone else experienced this problem? If you have, have you come up with any sort of workaround? Possibly I'm doing something wrong? I'm pretty sure everything is set up correctly, as it's all relatively straightforward ...
On another side note, is it possible to have the Win500 Scanner Server support more than one concurrent client connection? I would like to be able to run the scanner from home, and have myself logged in from work on 2 separate computers to monitor it, but I seem to only be able to get one on at a time and I can't find a setting to change in order to allow more than one user.
Thanks all for your time and any insight you can provide!!
** I just realized that this is possibly in the wrong forum, but it seems more like a Win500 issue than a general recording issue ... Mods, feel free to move this if necessary - thanks!
