Go Back   The RadioReference.com Forums > Computer Aided Monitoring and Programming > Scanner Programming Software
Scanner Programming Software - This is the place to discuss third party scanner programming and control software.
  #581 (permalink)
Old 04-24-2014, 4:46 AM
Butelsoftware's Avatar
Originally Posted by kikito View Post
(Using ARC536PRO, Version 0.91, Build 1, Full Version)
On the Find Duplicates screen, where did the pinkish 'Delete Selected Channels' button go?
In current build there is a problem with this option so was disabled to avoid data corruption. Once the option is updated it will be enabled again.
Gommert
Butel Software
>>> Visit us at the 2018 Dayton Hamvention! SDS100 will be on demo! <<<
Dutch Design: best selling scanner software in the USA
US Sales: 1-800-SCANNER http://www.scannermaster.com/?Click=41054
  #582 (permalink)
Old 04-24-2014, 1:05 PM
Default ARC 536/436 Beta
OK, thanks for the response Gommert. Sorry if it was answered before and I missed it.
JustMeAndMyRadios
  #583 (permalink)
Old 04-27-2014, 2:43 PM
alphaacres's Avatar
Have found a few bugs
The character counter is in the talk group / frequency column and not in the alpha tag column.
The charm bar in windows 8.1 is coloring everything black on the right side the width of the charm bar and also moving the up and down arrows to as far over to the left as the charm bar goes.
  #584 (permalink)
Old 05-21-2014, 3:41 PM
Question ARC536PRO
Is there an online manual available? It have it running, but have questions and thought I'd read through the manual (RTFM), but I can't seem to find one......is there one yet?
THX
Disregard for now.....I found the PDF that is with the download unless there is anything more recent.
  #585 (permalink)
Old 05-30-2014, 7:51 PM
n2pqq's Avatar
Originally Posted by thecop View Post
You can drag the separator lines between the individual fields and make them wider. For example, you can use the mouse to move the line between Department and Hit Count to expand that field. Should expand the logging window.
FWIW I asked Gommert if he would consider separating the logging window from VC. No dice.
Thank you for that !!!
  #586 (permalink)
Old 05-30-2014, 8:53 PM
n2pqq's Avatar
In the next build could you center the radio in virtual control mode.
And just a thought how about a way to adjust font size in program.
Maybe a way to change color displays in virtual mode .
  #587 (permalink)
Old 05-30-2014, 11:35 PM
The radio can be centered in virtual control mode by right mouse clicking on the display and choosing Align Center.
Don't know about the other two things, however.
Gommert had been moving right along at dealing with issues, but it appears the pace has slowed down. There are some fixes that still need to be made.
  #588 (permalink)
Old 05-31-2014, 11:15 AM
The display section can be centered, do a right mouse click in the display area.
There are no plans to change fonts in ARC536 VC. I will add changing colors to the suggestions list.
Gommert
Butel Software
  #589 (permalink)
Old 11-05-2014, 2:20 PM
Default Naming files created by Virtual Control
The 396XT software allowed options for naming the audio files that are created by Virtual Control (frequency, start time, stop time, CTCSS, etc). I have not found these options in ARC536 - are they available? Thanks.
  #590 (permalink)
Old 11-05-2014, 9:01 PM
Are you looking for something different than what is shown below:
  #591 (permalink)
Old 11-06-2014, 6:14 AM
They will be added in a later build, for now the format is fixed.
Gommert
Butel Software
  #592 (permalink)
Old 12-22-2014, 7:33 AM
mancow's Avatar
Tonight was the first time I've used this software and I'm trying to get the hang of it.
I am working with favorites lists right now. Is there a way to see more than one list at once? It appears I have to read a list from the radio one at a time.
Is there an overall view of how the radio is laid out anywhere? I have several lists but I'm no lost as to what list has what favorites list quick key number and what not. I need a map of some sort.
Also, I can't seem to edit the actual name of the favorite list... at all. I want to change from Federal to FEDERAL but I can't.
  #593 (permalink)
Old 12-22-2014, 11:35 AM
Newbie Here:
I have a question regarding this software. Is there a way to download the FULL database for all of US or do i have to select a state, then download each county
Thanks in advance
  #594 (permalink)
Old 12-22-2014, 9:05 PM
No. ARC is intended to create Favorites Lists and not donwload the full database. Even if you could create a Favorites List with the full database, the size of the file would exceed the 1MB limitation.
  #595 (permalink)
Old 12-23-2014, 7:04 AM
Thank you
  #596 (permalink)
Old 12-31-2014, 3:06 PM
Came across something interesting today. While playing with the "Write Data" window, I checked the box for "Copy in Name". So when I push it to the radio I can see that in the FL name it shows the [F0] in the name. Kinda cool. Then my accident I checked that box off again when I did another update to the scanner and now I see [F0][F0] in the name. So of course I could keep doing that and really mess up the FL name that shows on the screen of the 436. So now the question...How can I edit the name of the FL if I no longer what that in the FL name or on my display? There is no way in the software that I can tell that allows you to edit the name of the FL list.
So the fix for me was to go into the SD card and modify the f_list.cfg file to remove the extra stuff that arc536 added in.
If the software allows me to add to the names of the FL's there should be a way to edit them as well to change them or whatever and not have to go into the SD card to modify it.
Also that check box is not included in the help file so it was trial and error for me. No damage done since I know how to edit the cfg files but that should not be the way the end user should have to go about making changes.
Guess my request is to have a FL editor added to the menu so if you want to change the name of any FL you can easily do that from within ARC536.
Ed Velez kd2pm2@gmail.com
Ham - KD2PM/GMRS - WPVJ796
GRE PSR800/Uniden BCD436HP/Bearcat 780/Radio Shack 2067
  #597 (permalink)
Old 09-03-2017, 1:31 PM
MedicDavid78's Avatar
Question
Gommert
Butel Software
Hey Gommert,
Hope all is well! I know this threat is a few years old but are you still doing any Beta Tests of the ARC-536 Pro software? Or are you not going to do anything else with it? Thanks!
David - WRAX515
Radios: XTS5000, XTL5000, XTS2500, HT1250, Baofeng UV-5R, Anytone D868, CS-800D
Scanners: Uniden BCD536HP, Uniden BC246T
Pagers: Unication G1, Minitor 5
  #598 (permalink)
Old 09-04-2017, 10:00 AM
Beta testing has ended. We are still adding new features and improvements.
Gommert
Butel Software
