Go Back   The RadioReference.com Forums > Computer Aided Monitoring and Programming > Scanner Programming Software
Scanner Programming Software - This is the place to discuss third party scanner programming and control software.
Old 02-12-2014, 6:56 PM
Talking ARC 536/436 Beta
Been testing the beta version!! Build 7 out tonight...best so far!! Getting close!! Woo Hoo!!
Old 02-12-2014, 7:14 PM
Did you have to configure anything to get the virtual interface to work? How about run as administrator, is that necessary? No luck with the virtual as yet. Device Manager shows it on com4 and says it's working properly.
I'm running Win8.1 Pro, just FYI.
Old 02-12-2014, 7:34 PM
OK, I can answer my own question.
As a standard user, even run arc536 as an administrator the virtual interface won't run. When I log in as administrator it does.
Check Device Manager under ports to find out which port has the Uniden driver installed, enter that number in the box next to the start but and then click start.
Old 02-12-2014, 7:51 PM
Thanks! I had the same issue as you. I did not know the number on the left of the Start button was the Com port number. Works fine!! By the way, I am not running ARC536 as an administrator.
Lacadien72
Uniden BCD996T | Uniden BCD436HP | Uniden BCD536HP
Old 02-13-2014, 12:48 AM
zzdiesel's Avatar
Where can we download it?
Whistler - TRX-1 /w EZ-Scan
Old 02-13-2014, 4:57 AM
Yes, I have the same question. Bought the pre-release PRO version. Got a reply to mail Butel if I want to try beta version. I replied yes. Still no reply from Butel on where to download. Would like to try it. I know Butel says that their software is no replacement for the Sentinel for HP1 and x36HPs. And that is true. But the Sentinel is also no replacement for the Butel software. I still much prefer downloading directly from RRDB, the virtual control, and logging features.
Steve AA6IO
Old 02-13-2014, 5:31 AM
zzdiesel's Avatar
I'll buy the pre-release version today. Thanks for the idea. What are the differences in the basic & pro versions?
Old 02-13-2014, 6:11 AM
zzdiesel
As far as I know, difference between basic and PRO is that PRO also has virtual control and logging functions. I have Butel software for many other scanners, all PRO versions, and generally use the software a lot. If you find site to download new beta version, please post here or PM me.
Thanks.
Steve AA6IO
Old 02-13-2014, 10:29 AM
nr2d's Avatar
I still can't see my BCD536HP on my computer even with the Uniden drivers installed. The only way to get the computer to recognize the scanner is to plug the scanner in via the USB connection and tell the scanner to use the serial connector.
Is there anyway to keep the scanner in the serial mode?
Old 02-13-2014, 11:05 AM
Default Re: ARC 536/436 Beta
You are connecting properly, pressing serial mode is all you do on fhe scanner.
Look in device manager, ports for your scanner after you connect.
If you don't see the scanner. Disconnect, reboot, reinstall driver, reboot, connect scanner and look fod it again.
73, K8HIT
Icom: IC-7300, ID-5100A, ID-51A Plus 2, IC-R30 Yaesu: FT2DR & FT70, Hytera PD782G, Uniden SDS100
DVMega running Pi-Star: D-Star, DMR, System Fusion, P25, NXDN
Old 02-13-2014, 1:44 PM
DaveIN's Avatar
Founders Curmudgen
You also have to select the port from the unlabeled pull down that you use (com port in device manager) from the ARC virtual scanner and then select start.
Pop' Comm Monitoring Station ID: KPC9DV
CRB Research Monitor Station Registry: KIN9GP
GMRS: WQKL769
MARC ID:3126326
The BEST scanner or receiver is the one you using right now.
Old 02-13-2014, 3:42 PM
zzdiesel's Avatar
I just pre-ordered & paid for the Pro version. How can I download the Beta?
Old 02-13-2014, 4:24 PM
They sent me an email with a link shortly after the purchase.
73, K8HIT
Old 02-13-2014, 4:36 PM
zzdiesel's Avatar
Ok. Sounds good. Thanks.
Old 02-13-2014, 4:44 PM
I pre-ordered couple of days ago, sent several e-mail messages to try beta version, and still no response. I used the contact e-mail at yahoo.com but still nothing. Anyone have any further information. Thank you.
Steve AA6IO
Old 02-13-2014, 4:47 PM
Butelsoftware's Avatar
Steve AA6IO
please send me a PM with the email used to make the purchase.
Gommert
Butel Software
>>> Visit us at the 2018 Dayton Hamvention! SDS100 will be on demo! <<<
Dutch Design: best selling scanner software in the USA
US Sales: 1-800-SCANNER http://www.scannermaster.com/?Click=41054
Old 02-13-2014, 4:51 PM
Gommert,
Thank you for quick response. My error, I just checked spam e-mail and there was your reply with information. Sorry for confusion. Thank you very much. Will try out and report my findings.
Steve
Old 02-13-2014, 4:55 PM
Gommert:
I just sent you an email on instructions on how to use the discount coupon that I bought last November to use toward a preorder of the ARC 436/536 PRO software. I really want to try out the beta.
Butel has some great software and I can't wait to try it. Loved the ARC home patrol.
Thanks for any and all help
Currently scanning West Texas with a SDS100, BCD536/436, TRX-1 and Unication G5
Old 02-14-2014, 4:55 PM
Thanks Gommert for the reply and setting me up with the Beta. Butel: Great company and Great products! Thanks again.
Old 02-14-2014, 5:39 PM
Build 8 is now available. So far I've been pretty impressed.
