NFR85
- Joined
- Oct 25, 2007
- Messages
- 575
I'm trying to use Pro Scan and when I select a com port the only comport available is 3. And get "No Response" I have done the following.
1. Used Serial to USB and get an error message code 10 and other codes that it does not work.
2. I tried using the front port. Used the wire it came with and it brought up Windows Device BCD536HP serial port error message asking me to install the driver.
3. I tried downloading Up man's drivers I unzipped it and there is nothing in the folder to use for the driver. I have Windows Vista.
What step am I'm missing? The scanner and the computer is not recognizing the comport and giving me all these errors. I have screen shots of each error.
