Go Back   The RadioReference.com Forums > Computer Aided Monitoring and Programming > Scanner Programming Software
Scanner Programming Software - This is the place to discuss third party scanner programming and control software.
Old 02-12-2017, 1:50 PM
Default ID Tracker III - V1.20.1 Released
- Corrected caption in settings for Log Path.
- Minor correction to start up sequence.
Download: ID Tracker III
Change History: ID Tracker III Version / Install Notes
David M. Hitchner - K5DMH
Baton Rouge, LA
ID Tracker I/II/III
Old 02-12-2017, 2:04 PM
Thanks David for your continued support. Great Program.
However, just downloaded the new file and the Title Bar is still showing V1.20.0
Old 02-12-2017, 3:04 PM
Sorry about that. It's been a while since I posted an update and missed a step. Please try again.
Baton Rouge, LA
ID Tracker I/II/III
Old 02-12-2017, 3:18 PM
Problem resolved, Thanks!
Old 02-16-2017, 9:35 AM
zwc's Avatar
zwc zwc is offline
Default DMR Support?
David,
Love your program. Loyal supporter. Do you anticipate support for DMR?
Old 02-17-2017, 11:21 AM
Originally Posted by zwc View Post
David,
Not in the near future. I would need to either own a DMR scanner or have someone do some testing for me. Depending on how it's implemented it may not be that difficult to support.
Baton Rouge, LA
ID Tracker I/II/III
Old 02-28-2017, 9:49 AM
W4KRR's Avatar
I am using ID Tracker III version 1.20.1 with a Uniden BCD396XT. I notice under the "System Control" window, it only shows the first 9 systems, the remaining 90 aren't displayed. Is this an error, a setting, or a misconception on my part? I noticed that in ID Tracker II there are similar icons for all 99 system Quick Keys.
Ken
Old 03-01-2017, 5:05 AM
W4KRR's Avatar
Disregard my above post; issue resolved.
Ken
Old 04-22-2017, 7:01 PM
Default id tracker iii
Hi David any chance the program will work with the uniden BCD325P2 ?
i know the portable 325 is supposed to be very similar to the BCD396 home scanner
thx, John
Old 01-02-2018, 11:35 AM
I just downloaded and installed IDTracker III. I cannot figure out how to get to the import screen to import from RadioReference. I did find it once and imported information but I can't seem to get to the login and import screen again.
What am I missing??? (besides my memory)
Thanks for any help..
John
Old 01-02-2018, 12:10 PM
I don't believe that you can import the info directly to the ID Tracker program. You would need to import the info into the scanner and then run ID Tracker which will pick up the info from the scanner after it scans.
Old 01-02-2018, 1:10 PM
Thanks for the reply, Richard. I wasn't sure what exactly it imported but I know it can bring in the talk groups. I can't find the screen to log into Radio Reference. I did it earlier today - put in my name and password and actually imported the talkgroups from it. But I never could get back to it.
I'm using Freescan to actually program the scanner. Maybe I should go back and read what exactly it does. At this point, I just want to find the Import Files page.
Thanks again,
John
Old 01-02-2018, 2:47 PM
Default ID Tracker Import
The import functions can be accessed from the System Settings dialog. Under File there are Import and RR Import functions.
Baton Rouge, LA
ID Tracker I/II/III
Old 01-02-2018, 4:27 PM
Thanks David - I thought I was going batty!
John
