Go Back   The RadioReference.com Forums > Computer Aided Monitoring and Programming > Scanner Programming Software
Scanner Programming Software - This is the place to discuss third party scanner programming and control software.
Old 09-12-2017, 5:24 PM
Question ARC XT-Pro saving help please
When I change a system name from say "Maritime" to "Marine" and send it to the scanner, that works just fine. However the original rsf file NAME still shows as Maritime when I look at the directory holding the files and profile! Why does this happen and can I change that easily?
Neil Bell, KJ6FBA
Old 09-12-2017, 10:32 PM
When you first create a System, the software uses the System name as it's file name for intial saving more for default purposes than anything.
This is similar to what Microsft does in word files. If you write a letter that starts off with "Dear Bob" it will offer "Dear Bob.docx" as the file name. Should you later open that word file and change the letter to say "Dear Jim", the name of the file will still remain "Dear Bob" even though you've changed the words contained in the file.
To give the file a new name, go to File>Save System As and input the new name. Bear in mind you will continue to see the old/original file if you do some Windows Exploring.
Also if you give the file a new name, then if using a Profile, you might want to close the original file and save the Profile. (Profiles get file names, rather than system names).
Tags
arc xt pro, rsf names
