Freescan beta 2.19
marksmith
Anne Arundel County, MD
This new beta is out and has beta DMR support. This will be good for 996 p2 and 325 p2 users.
536/436/ws1095/996p2/996xt/325p2/396xt/psr800/396t/HP-1/HP-2 & others
ka1air
Color Code and NAC Numbers
I downloaded the beta 2.19 and have been working with it for several hours.
Noticed that for color codes there is a NAC number in that field.
CC1 = 1001
CC2 = 1002
CC10 = 100A
Where do you get a listing of the color codes and the numbers that relate to them
troymail
Silent Key
If I had to guess, it just looks like "10" followed by the HEX representation of the color code....
1001 = 1
1002 = 2
1009 = 9
100A = 10
100B = 11
100C = 12
100D = 13
100E = 14
100F = 15
ka1air
troymail
Thanks for quick response. Will have to give that a try when I get more DMR to program in.
Thanks again.
KA1AIR / Jack
lucky43113
Central Ohio/Pickaway County
i got it the beta downloaded but i am getting an error any thoughts how to fix this?
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.IO.FileNotFoundException: Could not load file or assembly 'NAudio, Version=1.6.0.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified.
File name: 'NAudio, Version=1.6.0.0, Culture=neutral, PublicKeyToken=null'
at FreeSCAN.frmCtlSetup.Timer_Renamed_Tick(Object eventSender, EventArgs eventArgs)
at System.Windows.Forms.Timer.OnTick(EventArgs e)
at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
WRN: Assembly binding logging is turned OFF.
To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1.
Note: There is some performance penalty associated with assembly bind failure logging.
To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog].
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.7.2600.0 built by: NET471REL1LAST
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
FreeSCAN
Assembly Version: 0.8.3.0
Win32 Version: 0.8.3.0
CodeBase: file:///C:/Users/lucky/Desktop/FreeSCAN.exe
Microsoft.VisualBasic
Assembly Version: 10.0.0.0
Win32 Version: 14.7.2556.0 built by: NET471REL1
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System
Win32 Version: 4.7.2556.0 built by: NET471REL1
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Core
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Configuration
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
Win32 Version: 4.7.2612.0 built by: NET471REL1LAST_B
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
System.Runtime.Remoting
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
Microsoft.VisualBasic.Compatibility
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic.Compatibility/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.Compatibility.dll
System.Speech
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Speech/v4.0_4.0.0.0__31bf3856ad364e35/System.Speech.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
ka1air
error message
lucky43113,
I got the same error message.
After I uzipped the file. I put the Freescan.exe file in the root directory with all the other freescan files and then deleted the olf freescan.exe file. It worked after that with no problems.
ka1air/jack
lucky43113
Found a solution
Re: FreeSCAN 2.19 Beta1
« Reply #4 on: Today at 07:54:58 AM »
Quote
Lucky
I had this same issue all i did to resolve it was replace the Freescan.exe for this release and it worked
Basically rename the original Freescan.exe to something different and copy this exe to that folder and it should work, or at least it did for me
Alrib123
Search Color Code
How would we program in the NAC to tell it to search for the cc?
Ronaldski
MI DB Admin
Bay City MI
Here is a link I made for the 2.19. It somewhat supports DMR. There's no color codes support, if you download from RR DMR's show as Unknown.
https://www.dropbox.com/s/2upoibhmk2xuyln/FreeSCAN 2.19 .zip?dl=0
He didn't make a full setup program you just use the .exe in the compressed folder and put in the existing freescan folder.
Yep unfortunately Assaf the author has more-less stopped doing anything with freecan. The forums are normally more down then up and even then doesn't get much usage.
Ronaldski
MI DB Admin
Bay City MI
Ron.
When I extract the ZIP, it asks for a password.
Care to share it?
Will this work as an upgrade to 2.05 on a 325P2 using XP?
There's no password, I even rechecked it by downloading it, as I expected since I did not password it in first place no prompt seen here.
In upper right at my link, click Download, then Direct download.
Here is a link that will download it upon clicking, only difference is last # is 1
https://www.dropbox.com/s/2upoibhmk2xuyln/FreeSCAN 2.19 .zip?dl=1
allend
Long Beach, CA
lucky43113,
ka1air/jack
Yup worked this exact way for me too
CT
Smokey4176
Northern Nevada
Help
lucky43113,
ka1air/jack
How would I do this?
