Big Problem
Mrbadness
Port Charlotte, Florida
I'm using Proscan software to program my scanner and when I disconnect the cable the scanner shuts off and won't start up. when i connect back up to the computer it works again. Can't figure it out. can anyone help
iMONITOR
Silent Key
S.E. Michigan
What scanner? Serial port, or USB port? Are you shutting down the software before disconnecting the scanner?
KC1UA
Scan New England Janitor/Maintenance
Marstons Mills, Cape Cod, Massachusetts
Sounds like a portable scanner that is powered by the USB connection and either has dead or no batteries installed. Just taking a guess based on the vague info.
