Go Back   The RadioReference.com Forums > Computer Aided Monitoring and Programming > Scanner Programming Software
Scanner Programming Software - This is the place to discuss third party scanner programming and control software.
  #21 (permalink)
Old 03-29-2018, 5:45 PM
Doesn't even detect my scanner via usb to usb. Didn't want to do the wifi route. ARC and Sentinel have always been plug and play no problem. Just thought I'd try ProScan from what I've been reading in this thread until the others are NXDN updated. Manual states you can use the software via scanner front usb to computer usb.
  #22 (permalink)
Old 03-29-2018, 6:07 PM
marcotor's Avatar
Thank you Bob!
Impressive Scanner/Radio list:
  #23 (permalink)
Old 03-29-2018, 6:09 PM
WX4JCW's Avatar
yes just click the com port button and then auto Detect
https://www.youtube.com/watch?v=iZGjncQLdJ0
Jason WX4JCW EMD/FF/EMT RET
Like Johnny Cash's Song I've been everywhere man, ive been everywhere and monitored it
XPR7550, BCD536HP, SDR
  #24 (permalink)
Old 03-29-2018, 6:23 PM
Originally Posted by mule1075 View Post
I use wifi for programming all the time.
Really ? never seen support. How do you get it to even see the SD?
SDS-100, BCD536,Hp2(e),HP-1(e)x2, BC780, BCD996t ,BCD996P2, BCD325P2, Pro 2005, 2006(x2), Pro34,VR500,AT803,R5000 and other RF capture devices
  #25 (permalink)
Old 03-29-2018, 6:28 PM
jonwienke's Avatar
Has anyone ever had ProScan work on 536 via front usb to computer usb? Have never been able to get this software to work with x36 scanners.
I've never had any trouble getting the USB port to work for programming or data communication. For remote access, monitoring, and logging, Wi-Fi is the best. You have to use USB to update programming though.
  #26 (permalink)
Old 03-29-2018, 6:54 PM
mule1075's Avatar
Never mind my mistake need to learn how to read. Sorry for the confusion.
Uniden BCD536HPx2/250D Motorola HT1000/GM360
  #27 (permalink)
Old 03-29-2018, 6:55 PM
Thanks for the info, All good now. Going to work with NXDN now. Had a couple I manually programmed in my scanner but now it might be easier.
  #28 (permalink)
Old 03-29-2018, 8:23 PM
werinshades's Avatar
Originally Posted by WX4JCW View Post
12.11 is out, there was an channel number issue
What was the channel number issue?
  #29 (permalink)
Old 03-29-2018, 8:54 PM
WX4JCW's Avatar
It was downloading them as 1,2,3,4,5,6 etc
See the other thread
Sent from my iPhone 8 using Tapatalk Pro
Jason WX4JCW
Unication G4, BCD536HP
  #30 (permalink)
Old 03-29-2018, 9:47 PM
Jason WX4JCW
Which thread might that be? I'm running 12.10 without issues.
  #31 (permalink)
Old 03-29-2018, 10:01 PM
ProScan's Avatar
On ver. 12.10 Importing from RRDB NXDN Trunk systems, was using the LCN value. Ver. 12.11 uses the CH ID param.
  #32 (permalink)
Old 03-29-2018, 10:03 PM
Thanks Bob. I usually don't import from RRDB, that's why I was wondering what the issue was...thanks.
  #33 (permalink)
Old 03-29-2018, 10:33 PM
WX4JCW's Avatar
Default ProScan NXDN Support Available
Deleted
Jason WX4JCW
  #34 (permalink)
Old 03-30-2018, 10:32 PM
12.12 is the current version..
  #35 (permalink)
Old 03-31-2018, 5:40 PM
Are there any detailed instructions or videos on importing from RRDB in ProScan? Can't find anything on the internet or clear details in the manual to do this procedure. The manual states that ProScan can import from RRDB but does not give details on how. Makes a great virtual on computer and can project as many scanners as computer can handle.
  #36 (permalink)
Old 03-31-2018, 7:17 PM
WX4JCW's Avatar
ill throw something up real quick
  #37 (permalink)
Old 03-31-2018, 7:19 PM
thecop's Avatar
FAVORITES EDITOR -> FILE > Import RadioReference web (RR Subscription Required)
"We sleep safe in our beds because rough men stand ready in the night to visit violence on those who would do us harm" George Orwell
  #38 (permalink)
Old 03-31-2018, 7:20 PM
Sanscanman's Avatar
In the Favorites Editor (NOT the Window with the virtual Scanner)
Select File and look down at the 7th option (import RR web Subscription required).
You may have to select File>New first to populate a blank database before importing.
make sure you remember to save.
UNIDEN: BCD396T-BC246T-BC296D-BC250D-BC780XLT
RADIOSHACK: Pro-668 - Pro-18 - Pro-107 - Pro-96 - Pro-2067
GRECOM: PSR-500 PSR-800
M/A COM: LPE 200
  #39 (permalink)
Old 03-31-2018, 7:21 PM
WX4JCW's Avatar
https://www.youtube.com/watch?v=BAqqb7Pn2q8
  #40 (permalink)
Old 03-31-2018, 7:36 PM
I've got the 30 day trial version. When I click on Import Radio Reference Web I get "A Database File Must Be Open". Then it says Click On Database Menu and Click New Or Open. What does this mean? I do not get the Radio Reference Window.
