Go Back   The RadioReference.com Forums > Computer Aided Monitoring and Programming > Scanner Programming Software
Scanner Programming Software - This is the place to discuss third party scanner programming and control software.
  #61 (permalink)
Old 04-02-2018, 11:46 PM
WX4JCW's Avatar
Originally Posted by ProScan View Post
Are you talking about the Alert Color and Slow or Fast Blink? I'll put it on the list. I think this is more of a suggestion then a con.
The Favorites List are in the file "f_list.cfg" They are named exactly like in the Favorites Editor (which can be renamed) and in the scanner. One of the objectives of ProScan is to follow the scanner database structure exactly. In line with that, I will keep it the way it is now.
Yes the alert color
Ok so for me Proscan has no cons lol
Sent from my iPhone 8 using Tapatalk Pro
Jason WX4JCW
Unication G4, BCD536HP
Jason WX4JCW EMD/FF/EMT RET
Like Johnny Cash's Song I've been everywhere man, ive been everywhere and monitored it
XPR7550, BCD536HP, SDR
  #62 (permalink)
Old 04-03-2018, 5:55 AM
ProScan's Avatar
Originally Posted by kbod9633 View Post
Ive imported the following system and a few others
https://www.radioreference.com/apps/db/?sid=8938
using Proscan I have all favorite lists disabled except for the one with this system in it
and all i get is nothing to scan
seems if i enter the system using proscan it wont work i can go into scanner edit favorite and its all in there it just wont scan it
if i enter it directly into 436/536 it will scan??
its gotta be something simple im not seeing
thanks
Go into the menu Set Scan Selection -> Select Lists to Monitor then turn on the Favorite list.
This happened because a new file was created with a new Favorites list. The new favorites was defaulted to Scan Off. Next release will be changed to default On on the Favorite list .
  #63 (permalink)
Old 04-06-2018, 7:22 AM
ProScan's Avatar
Originally Posted by WX4JCW View Post
Easier way to assign colors depending on service type
This is implemented already. It's in the Find & Replace function under the Utilities menu. Select Conv. or Trunking Channels. Select Service Type for the parameter. Select the Alert Color in the Find What box.
  #64 (permalink)
Old 04-06-2018, 8:44 AM
kibler's Avatar
Default Q&A
ProScan.......When I WRITE back to my 536HP, is there a progress bar somewhere onscreen that tells me the process has completed? Thanks
  #65 (permalink)
Old 04-06-2018, 8:45 AM
ProScan's Avatar
It's on the list of things to do.
  #66 (permalink)
Old 06-09-2018, 9:19 AM
Default ProScan and NXDN
Good morning
I'm using Pro|Scan and uniden 436 to monitor NXDN and I bough the key but for some reason a get no audio at all.
Anybody else having problems getting audio using Proscan? This is the group I want to follow:
https://www.radioreference.com/apps/db/?sid=9247
Thanks for your help
Luc
  #67 (permalink)
Old 06-11-2018, 3:12 PM
ProScan's Avatar
Originally Posted by lucll24 View Post
Good morning
Luc
Is the 436 scanning the system in question? If no, did you import the Site/s and frequencies. Did you import the department and TGID's? Try ID Search to see if it picks up traffic.
  #68 (permalink)
Old 06-11-2018, 5:34 PM
kbod9633's Avatar
Good morning
Luc
Did you try running lcn finder on the sites?
Looking at the db Iím thinking those Lcnís may be wrong I could be wrong but Iím betting they are wrong
If you donít have the correct lcnís for each freq your not gonna hear anything
Bob
3 BCD536HP's , 2 BCD436HP's , BCD996XT, 2 TRX-1's , PRO-96
