Having an issue and not sure if this is the correct place
When uploading 1 system either on an add or append it seems to upload the same system over and over again,
Each system that is in the scanner the highlighted line moved down each even though it is not selected but instead of sending the one that is not selected it seems to resend the one that is.
I find that the only way to stop this is to send all after erasing the scanner and uploading all.
Can someone else confirm if this is happining to you or was there a update to the software or scanner
I am using Freescan 2.19 Beta1 Scanner Version 1.07.09 in a 996p2
Windows 7Pro
Thanks in advance
Windows 7Pro
Thanks in advance
