Go Back   The RadioReference.com Forums > Computer Aided Monitoring and Programming > Scanner Programming Software
Scanner Programming Software - This is the place to discuss third party scanner programming and control software.
Old 04-27-2018, 4:18 PM
Default Need little Help
This is ProScan software. Not for sure what it is telling me in system/site & talk group column. The Unknown part? SRC? & DST?
Old 04-27-2018, 4:23 PM
That's an I-call (radio-to-radio call). SRC is Source and DST is Destination
1004 called 1013, then in the next line 1013 talked to 1004..
Old 04-27-2018, 5:34 PM
Thanks Voyager. Now is their a way program I-call yet? I'm behind on this one.
Old 04-27-2018, 5:56 PM
Which model scanner?
In Uniden models that support it, you program it using an i followed by the RID, or i0 for all. "i" is entered on the keypad with the decimal point.
Old 04-27-2018, 6:18 PM
Have a 536HP. Is there a group talk on this some where? Get like more info.
Old 04-27-2018, 6:25 PM
ProScan's Avatar
Program I-Calls like Voyager advises.
Here is the Easier to Read Manual in case you don't have it. Easier to Read BCD436/536HP Digital Scanner Manual
Most Popular & Feature-Rich Scanner Software For The Uniden's
ProScan - RadioFeed Home Page
bob@proscan.org
Old 04-27-2018, 6:37 PM
Ok. Think I have this. It is just like entering regular TGID's then. Is I-call used in DMR?
Old 04-27-2018, 6:40 PM
Just like TGIDs except that it has the "i" in front of it. You can have a Group of only I-call IDs, or do what I do on one scanner - program then then avoid that Group. That way I hear icalls except from a particular group.
Yes, DMR uses I-calls, too. (or CAN use them - different systems may or may not actually use them.)
