Go Back   The RadioReference.com Forums > Computer Aided Monitoring and Programming > Scanner Programming Software
Scanner Programming Software - This is the place to discuss third party scanner programming and control software.
Old 04-29-2018, 1:11 AM
Default P25 Phase I w/ frequencies instead of talkgroups
Has anyone encountered this on radioreference.com?
BC75XLT, BCD325p2
Old 04-29-2018, 1:33 AM
Johnnydollar2's Avatar
Default P25 Phase 1 W/Freqs instead of Talkgroups
I had this happen once but with my WS1080. I purposely entered the SITE freqs as CONVENTIONAL objects instead of as a P25 SYSTEM just to test the CChannel trunked signal strength. You sure you didn't do THAT instead of entering the thing as a P25 System?. ON Trunking scanners that is pretty much the only way your freqs will show up in a scan instead of Talkgroups.
Old 04-29-2018, 1:52 AM
My scanner is the UBCD325p2. I tried to set it up as a; Motorola 800 Type I
The data below. Is from this page: https://www.radioreference.com/apps/...=1200#cid-1082
Harford County Fire/EMS
Central Maryland Area Regional Communications Committee (CMARC)
Project 25 Phase I Most Fire/EMS operations use this system.
Frequency License Type Tone Alpha Tag Description Mode Tag
460.60000 KGD273 RM 136.5 PL FE DISP C1/4 Dispatch FMN Fire Dispatch
460.57500 KGD273 BM MDT DATA 1 Mobile Data Terminals Telm Deprecated
460.62500 KGD273 BM MDT DATA 2 Mobile Data Terminals Telm Deprecated
453.72500 M 136.5 PL HAZMAT CH7 Hazmat FM Deprecated
Harford County Sheriff
Project 25 Phase I Most Sheriff operations use this system.
460.37500 WNMR761 BM MDT DATA 1 Mobile Data Terminals Telm Deprecated
460.07500 WNMR761 BM MDT DATA 2 Mobile Data Terminals Telm Deprecated
460.30000 WNMR761 BM MDT DATA 3 Mobile Data Terminals Telm Deprecated
460.12500 WNMR761 BM MDT DATA 4 Mobile Data Terminals Telm Deprecated
453.01250 WNYU786 M CDC BASE Detention Center Base FM Deprecated
458.01250 WNYU786 M CDC OFFICERS Detention Center Portables FM Deprecated
Harford County Services
Project 25 Phase I Most county services use this system.
37.94000 BM 110.9 PL CHANNEL 1 Public Works FM Public Works
37.96000 BM 110.9 PL CHANNEL 2 Public Works FM Public Works
37.90000 WNUH274 BM 110.9 PL CHANNEL 3 Public Works FM Public Works
37.92000 WNUH274 BM 110.9 PL CHANNEL 4 Public Works FM Public Works
33.74000 KGD273 BM CIVIL DEFENS Civil Defense Sirens FM Deprecated
461.22500 WQBD785 RM 141.3 PL DWS CH1 Department of Water and Sewer FM Deprecated
155.08500 KUI559 RM 110.9 PL DWS CH2 Water & Sewer FM Deprecated
154.08500 WPUF781 M 123.0 PL DWS CH3 Water & Sewer FM Deprecated
453.95000 WNBT657 RM 123.0 PL PERMITS Permit & Development FM Deprecated
173.39000 WNRJ925 F SCADA DATA Departmenrt of Water and Sewe - SCADA (5 sites) Telm Data
Harford County 800 MHz Talk-Around
867.76250 M G3 FDPD T/A Fire-Police Direct FM Deprecated
868.51250 M FD DIRECT TA Fire Direct FM Deprecated
How can it be a P25 Phase I with frequencies, instead of talkgroups?
BC75XLT, BCD325p2
Old 04-29-2018, 2:11 AM
Having all that info ahead of time would have helped. I see a lot of "deprecated" listings. Only P25 I see is the CMARC and it's a 700mhz System Control Channel from what the link shows with only a few unnecessary 800mhz freqs. Why set it up as a Moto 800mhz type 1 when it's a P25? Maybe someone with that scanner can address it. I can't make sense of any of this. Like I said. Only time I got that result was when it was entered incorrectly on purpose just to test signal strength on a freq.
Old 04-29-2018, 5:07 AM
jonwienke's Avatar
Deprecated means they are NO LONGER USED.
The county has mostly migrated to the CMARCS system which is listed on a separate page. Go to the CMARCS page and you will find the info you are looking for.
https://www.radioreference.com/apps/db/?sid=6859
Old 04-29-2018, 7:37 AM
iMONITOR's Avatar
I think it would be a nice option when viewing the database if you could hide the deprecated listings completely.
