ARC536Pro
Theo
New Port Richey, FL
Looking for some help with my Arc software trying to get my BCDx36HP to be read in ARC. I get the green light that's it. Step by step instructions would be appreciated. Thanks. ARC536Pro ver. 2.1 build 6.
eaf1956
Evansville, IN
When you get the Green light...Check the boxes to select the systems.
Then select the button labeled READ SELECTED
ofd8001
Louisville, KY
Are you seeing Favorites Lists displayed in the pop-up window? If you are not, I think you may not be connected to the scanner. You can confirm this by looking at the blue field in the attached image.
If you are seeing Favorites Lists, you can read all of them by clicking the "Read All Fav." button. Be patient if you have a lot of them as it takes several minutes.
Alternatively you click check the boxes beside which one or several FLs to read. Then click Read Selected.
When the reading process is completed, the popup closes and those FLs that were read appear in the browser.
Theo
New Port Richey, FL
I'm connected same as you No FL's are showing up! There's a bug in the software. I'm using 1.18.00.
Theo
New Port Richey, FL
Click on the Drivetest button, that will open a text file in notepad. Please post the contents of that file. And also a screenshot just like ofd8001
Gommert
Butel Software
ARC536
c: [OS]
d:
e:
f: [Backup Drive]
g:
E / 71 / E:\BCDx36HP\scanner.inf 69
F / 76 / F:\BCDx36HP\scanner.inf 70
G / 0 / G:\BCDx36HP\scanner.inf 71
H / 76 / H:\BCDx36HP\scanner.inf 72
I / 76 / I:\BCDx36HP\scanner.inf 73
J / 76 / J:\BCDx36HP\scanner.inf 74
K / 76 / K:\BCDx36HP\scanner.inf 75
L / 76 / L:\BCDx36HP\scanner.inf 76
M / 76 / M:\BCDx36HP\scanner.inf 77
N / 76 / N:\BCDx36HP\scanner.inf 78
O / 76 / O:\BCDx36HP\scanner.inf 79
P / 76 / P:\BCDx36HP\scanner.inf 80
Q / 76 / Q:\BCDx36HP\scanner.inf 81
R / 76 / R:\BCDx36HP\scanner.inf 82
S / 76 / S:\BCDx36HP\scanner.inf 83
T / 76 / T:\BCDx36HP\scanner.inf 84
U / 76 / U:\BCDx36HP\scanner.inf 85
V / 76 / V:\BCDx36HP\scanner.inf 86
W / 76 / W:\BCDx36HP\scanner.inf 87
X / 76 / X:\BCDx36HP\scanner.inf 88
Y / 76 / Y:\BCDx36HP\scanner.inf 89
Z / 76 / Z:\BCDx36HP\scanner.inf 90
C / 0 / C:\BCDx36HP\scanner.inf 67
D / 71 / D:\BCDx36HP\scanner.inf 68
Theo
New Port Richey, FL
ARC536
c: [OS]
d:
e:
f: [Backup Drive]
g:
It works fine on my laptop but not on my PC. Could it be because I have a Backup HD attached?
