Go Back   The RadioReference.com Forums > Computer Aided Monitoring and Programming > Scanner Programming Software
Scanner Programming Software - This is the place to discuss third party scanner programming and control software.
Old 05-06-2018, 11:19 PM
Default import DMR file from ATC XT pro to ARC _36 pro
I have several files on my 996 P2 which are DMR using the ARC XT pro
I am using the ARC _36 pro and have the version 2.1 build 6 beta
I am trying to import some of the files from the XT program that are DMR related.
Each time getting an error.
I tried checking for a update for the XT program and it says I have the most current version 2.1 build 5
Has anyone else been able to import DMR files and if so, how are you doing it?
Thanks, Scott
Old 05-07-2018, 5:50 AM
Butelsoftware's Avatar
What is the error?
Gommert
Butel Software
>>> Visit us at the 2018 Dayton Hamvention! SDS100 will be on demo! <<<
Dutch Design: best selling scanner software in the USA
US Sales: 1-800-SCANNER http://www.scannermaster.com/?Click=41054
Old 05-07-2018, 6:42 AM
Under import if I select 396/996 file I select a file name and it says: file not compatable, or saved in newer format.
Under ARC XT file I select a file name and it shows up along left side in browser box and it only says unsaved systems. There is no file name, no plus to expand with data and no other info. The file extension name has a .rsf after them if that helps.
