Go Back   The RadioReference.com Forums > Computer Aided Monitoring and Programming > Scanner Programming Software
Scanner Programming Software - This is the place to discuss third party scanner programming and control software.
Old 05-11-2018, 12:53 PM
AC0RV's Avatar
Default PROSCAN
I use the record feature on the X36HP series radio I have.
Now my question. Can the PROSCAN retrieve the records or doing I have continue download them by hand ?
This question may have been answered/ So please direct me to it.
Big thanks
The only way into heaven is through Jesus.
David F AC0RV
Skywarn # M187201
Old 05-11-2018, 1:47 PM
jonwienke's Avatar
If you have a 536, it's better to record in ProScan via the Wi-Fi connection. If you record in the scanner, you have to reboot into mass storage mode to retrieve the files. If you record in ProScan, recording is done directly to your hard drive.
Old 05-11-2018, 1:48 PM
AC0RV's Avatar
David F AC0RV
Skywarn # M187201
