Go Back   The RadioReference.com Forums > Computer Aided Monitoring and Programming > Scanner Programming Software
Scanner Programming Software - This is the place to discuss third party scanner programming and control software.
Old 06-11-2018, 10:41 AM
Default Mac or Windows?
I would like to get back into the scanner hobbie. I have a old RS Pro106 and would like to update to a Uniden SDS100. But I have moved on to the Apple world of computers.
Question : Should I get a old PC just to run my scanner software only or try to run a third party software on my Mac?
I never had to load software on my old PC, because someone else programmed my radio. I still have my PC in the closet.
Old 06-11-2018, 11:02 AM
Wiki Admin Emeritus
There is very little, if any, scanner software that is Mac compatible, although you can load Windows in a VM and that will work in at least some cases. See this article...
Mac Users of Police Scanner Radios | ScannerMaster.com
Stick with Windows - there's lots more available there. Mike
Old 06-11-2018, 5:36 PM
kbod9633's Avatar
I run proscan, ezscan and sentinel all using a program called crossover for Mac
You donít have to have windows installed
Bob
3 BCD536HP's , 2 BCD436HP's , BCD996XT, 2 TRX-1's , PRO-96
Old 06-11-2018, 5:38 PM
jonwienke's Avatar
Get a cheap netbook for programming. It's probably cheaper and less hassle than setting up Windows on a Mac and dealing with cross-platform driver quirks, etc.
Old 06-11-2018, 7:44 PM
All of the scanners software is very light, so you should be able to find a very reasonably priced laptop. They have deals on off lease and recycled corporate models.
https://m.newegg.com/productlist?key...%20hp%20laptop
If you really want to use your Mac, you can use VirtualBox for free (good option over VMware and parallels which add to the cost).
Sent from my iPhone using Tapatalk Pro
