ProScan: Can I program my BCD996P2
Ishmole
Walden, NY
I have tried, but have not had any luck. I can program my BCD536HP fine, and can control the 996P2, but have not had any luck programming the scanner.
Ishmole
Walden, NY
Can I program my BCD996P2?
I have no problem prgramming the BCD536, but can I program the BCD996P2?
cg
Connecticut
From ProScan's webpage....
ProScan supports the BCT15, BCT15X, BC250D, BC296D, BR330T, BC346XT, BC346XTC, BCD325P2, BCD396T, BCD396XT, BCD436HP, BCD536HP, BC780XLT, BC785D, BC796D, BCD996T, BCD996XT, & BCD996P2 scanners.
chris
jonwienke
More Info Coming Soon!
VA
You didn't notice that the 996 is listed in ProScan's Scanner Type list?
Ishmole
Walden, NY
Actually I am trying to read the scanner. It was already programmed with Freescan. I do see it listed on the list of scanners covered by the software, I just can't get it to read the scanner.
Am I doing something wrong? I am using the USB port connected to the scanner.
Ishmole
Walden, NY
Yes, of course. I thought maybe that just meant you can use Proscan to control the scanner from the computer which it does. I just cannot get it to read the systems and frequencies already in the radio. Perhaps I should have explained it more clearly. I connect the USB and all I get is the computer control screen, not the programming window.
Ishmole
Walden, NY
I am getting "Unable to open Comm Port. Check if other software is using port 3. There is no other software running on the computer =. I restarted it just to be sure.
Ishmole
Walden, NY
did you download and install the special driver software that is required for the 996p2.
No. Maybe that is the problem. Where can I download it?
Disregard! I just saw PROSCANS post.
Ishmole
Walden, NY
Ishmole,
Are you using the front port?
Did you install the serial driver? Instructions here -> BCD996P2 < UnidenMan4 < TWiki
After that, use the ProScan Comm. Port Auto Detect. Advise if it works or not
Thank You! I have got it up and running and able to program! I was looking for a separate programming window to open up like it does with the 536.
Very nice. The more I use it, the more I like it. I am glad I bought it.
Thank you for your support! Great program!
