Go Back   The RadioReference.com Forums > Computer Aided Monitoring and Programming > Scanner Programming Software
Scanner Programming Software - This is the place to discuss third party scanner programming and control software.
Old 06-11-2018, 5:22 PM
Ishmole's Avatar
Default Can I program my BCD996P2
I have tried, but have not had any luck. I can program my BCD536HP fine, and can control the 996P2, but have not had any luck programming the scanner.
Old 06-11-2018, 5:23 PM
Ishmole's Avatar
Default Can I program my BCD996P2?
I have no problem prgramming the BCD536, but can I program the BCD996P2?
Old 06-11-2018, 6:14 PM
cg cg is offline
From ProScan's webpage....
ProScan supports the BCT15, BCT15X, BC250D, BC296D, BR330T, BC346XT, BC346XTC, BCD325P2, BCD396T, BCD396XT, BCD436HP, BCD536HP, BC780XLT, BC785D, BC796D, BCD996T, BCD996XT, & BCD996P2 scanners.
chris
Old 06-11-2018, 6:17 PM
jonwienke's Avatar
You didn't notice that the 996 is listed in ProScan's Scanner Type list?
Gone camping.
Old 06-11-2018, 6:29 PM
how are you trying to program it and with what system etc?????
Old 06-11-2018, 9:03 PM
Ishmole's Avatar
Actually I am trying to read the scanner. It was already programmed with Freescan. I do see it listed on the list of scanners covered by the software, I just can't get it to read the scanner.
Am I doing something wrong? I am using the USB port connected to the scanner.
Old 06-11-2018, 9:06 PM
Ishmole's Avatar
Yes, of course. I thought maybe that just meant you can use Proscan to control the scanner from the computer which it does. I just cannot get it to read the systems and frequencies already in the radio. Perhaps I should have explained it more clearly. I connect the USB and all I get is the computer control screen, not the programming window.
Old 06-11-2018, 9:14 PM
Ishmole's Avatar
I am getting "Unable to open Comm Port. Check if other software is using port 3. There is no other software running on the computer =. I restarted it just to be sure.
Old 06-11-2018, 9:44 PM
did you download and install the special driver software that is required for the 996p2.
Old 06-11-2018, 10:02 PM
buddrousa's Avatar
Did you set the baud speed in the GPS port to match the usb port comport speed?
Support your local FIRE & EMS. PRO197-18-107-668:PSR-410 X2: BC8500XLT 785d BCD436HP SDS100 BCD536HPx4 BCT346 BCD996P2 x3 BCT15x2 BCT15X2 TRX-1 TRX-2 EFJ51SL MTX8250 TK2180 MD380x4 NX5300 NX5200
Old 06-11-2018, 11:00 PM
ProScan's Avatar
Ishmole,
Are you using the front port?
Did you install the serial driver? Instructions here -> BCD996P2 < UnidenMan4 < TWiki
After that, use the ProScan Comm. Port Auto Detect. Advise if it works or not
Most Popular & Feature-Rich Scanner Software For The Uniden's
ProScan - RadioFeed Home Page
bob@proscan.org
Old 06-12-2018, 10:47 AM
Ishmole's Avatar
No. Maybe that is the problem. Where can I download it?
Disregard! I just saw PROSCANS post.
Old 06-12-2018, 10:59 AM
Ishmole's Avatar
Originally Posted by ProScan View Post
Ishmole,
Thank You! I have got it up and running and able to program! I was looking for a separate programming window to open up like it does with the 536.
Very nice. The more I use it, the more I like it. I am glad I bought it.
Thank you for your support! Great program!
