Here is arc536pro_201_build6_setup.exe
https://www.dropbox.com/s/ikhbmebw0wijspo/fssetup-218-b6.exe?dl=0
I am using a Windows 7 PC. I just downloaded and installed arc536pro_201_build8_setup.exe.
A few observations with Build 8 [Build 81] in case Butel monitors this forum.
1. My AVG kept flagging the installer. After installing, AVG was flagging the executable. I had to exclude the directory "C:\Program Files (x86)\BuTel\ARC536PRO" and had to click on Trust this File to allow the installation to continue.AVG wanted to upload the file to its' servers for an offline analysis. UPDATE: AVG Free app notified me that the file was clean.
2. In the RadioReference WebService window, when "Enable Service Tags Filter" is checked in the Service Tags TAB, then when you navigate systems in the Data TAB, the "Plus" symbol does not show up on the left side of the systems, and you can't view the frequencies.
This happens with Conventional frequencies.
If I uncheck the "Enable Service Tags Filter", then go up to Agency Dropdown and pick a different item, which causes a reload from RadioRefererence, then the "Plus" symbol returns to the left side of a system in the Data TAB section, and you can view the frequencies.
3. In the RadioReference WebService window, when you click on Trunk Systems Button, Agency Label, below County label, changes to Trunk Systems. No problem. When you click on Nationwide button, the Trunk Systems label does not change back to Agency. If you click on Agencies button or Conventional Frequencies button, then the Trunk Systems label changes back to Agency.
