Same Method
Great, I don't have the software in front of me. I assume to highlight more than 1 line you hold the control key. Is that correct?
Thanks. This will certainly help me out.
If you highlight a whole row of talk groups, you can make the necessary changes; however, all that are highlighted will have the same exact LED flash pattern, LED color, and alarm tone.
After you have finished programming, make sure you go to "all objects" to see if any TSYS is unattached to the talk groups.
I always default everything I program with a listing of scan list one. Then, if everything is messed up, I can at least hear what I've programmed. I believe I messed after the 4th day in a row of attempting to program the statewide P25 system in Colorado, one of the densest I've programmed. When I looked, there were talk groups without any numbers. Please, be aware, if you have these it will emit a "heap error." It basically means the top is separated from the bottom on trunking systems.
You can also do this with conventional frequencies, forget to map one. I know it is tedious, but check your work. You will always find a radio system unattached, but that is supposed to be that way.
To double check you scan lists, go to each one programmed by clicking "show scan list" in the screen I provided. Then, you know that all have been accounted for in your effort.
I used to love my PSR 500, but it is dead due to the most annoying issue, the flimsy BNC housing. In time, I will send it in for repair. Your model of radio has the same chassis.
I hope this helps.
David
