jkraig
Is BCD996P2 made for P25 standard programming? Have downloaded P25 Standard for my area to ARC XLT PRO program, but my scanner doesn't recognize the file.
Looking at your county in the database, the only listed P25 channel is the Runnels Sheriffs Office.Is BCD996P2 made for P25 standard programming? Have downloaded P25 Standard for my area to ARC XLT PRO program, but my scanner doesn't recognize the file.
You are not hearing San Angelo? Do you have enough signal to receive that system from your neighboring county?
omit the group and sites i don't need
There is only one "site" for the P25 system. It's a simulcast, so there are four physical site locations (towers), but all of them use the same set of frequencies. The EDACS system does have several sites, but that system supposedly is no longer in use.San Angelo updated their system, so I was trying to update and download. San Angelo Fire and EMS is the key functions I need. I get plenty of signal strength. My problem is getting the system downloaded in to the scanner. I've pulled it from here into ARCXLT pro, omit the group and sites i don't need and upload in to the scanner. shows its stored, but doesn't show up in the scanning mode
You're welcome.Well after digging deeper into data that i don't understand to well with your advice, I realized that the download didn't pull the frequencies with the site info. II just figured that would have been something I didn't have to worry about. LOL, makes me feel really smart. Thanks so much for the time, advice, and knowledge which resulted in some confidence here. All is well and working great. Have a blessed weekend.
