Is there any programming soft ware that will work with a chromebook ,.or will there ever be ? for uniden scanners
I would not hold my breath. But you never know.
I was able to get sentinel installed on my chromebook using a program called crossover. But when i connect my scanner via the USB cable, the chromebook detects it as a storage device and not a scanner. Any possible suggestions.
Thanks in advance
When i plug it in and select Mass storage, the chromebook does nothing. When i go in and open up the folder for it, it shows it as a flash drive. Sentinel does not see it and when i go to download from scanner, it does not show the scanner
