Everything worked fine the other day now I am having an issue:
WS1065 Scanner ARC500 Software Radio Reference import
Example:
When using the RR import feature in ARC500 and you select "nationwide" then select railroads from the drop down menu. The green numbers on the lower right indicating the number of available frequencies and the number selected are showing 0/0 even with all frequencies selected. This is not exclusive to railroad frequencies. Some other categories work fine and others show the same 0/0 or even sometimes the number available will not be the correct number.
It is almost as if a server is offline that contains certain databases.
ARC500 is logged into radio reference, memberships all current.
Anyone else ever see a similar issue?
Example:
