737mech,
On your Favorites listing, do you use more than 16 Characters resulting in the "ID Tracker III - Messages" dialog box like mine shown on the right in the first picture? I guess just about all, if not all, of my Favorites exceed 16 characters. The 16 character limit on a Uniden BCD536HP display is what can be displayed in the lower right on the screen. I guess I could shorted the names so the whole name appears on the screen... :roll:
Aside from the "System Control" box, do you find the rest of the application behaving well?
Cheers! Dave
Since it have been a while since I wrote the code so I don't remember the exact reason but I have these comments in my source code:
' Systems in different favorite lists are treated as the same system.
' Favorites should be limited to 16 characters.
' System, Department and Site names should be limited to 25 characters.
' If using Close Call, use "Do Not Disturb" mode. The radio does not
' correctly report the scanner's status after a Close Call check.
I believe it may be that the code has to use the display information to determine the current status. Since the display has limited characters the information retrieved is limited. It would take some time to really analyze the code so at this point I will stick with my comments.
