The RadioReference.com Forums
-   Scanner Programming Software (https://forums.radioreference.com/scanner-programming-software/)
-   -   ProScan Version 1.7 Build 1 is out!!! (https://forums.radioreference.com/scanner-programming-software/87517-proscan-version-1-7-build-1-out.html)
ProScan 11-21-2007 4:28 PM
I just finished ProScan Version 1.7 Build 1. It now includes support for the BC 996. I'm thriving to make this the best! This version is Vista compatible and includes bug Fixes. Supported scanners are the BC 250, BC 296, BC 780, BC 785, BC 796, and now the BC 996.
The import/export routines didn't make it in as this version was over due. I'm planing a version that will have the import in it. I'll need ideals on this one.
Visit my site at http://www.proscan.org/index.htm Download ProScan and try it out. I hope you will like it.
Bob Aune,
ProScan
wjf 11-21-2007 5:50 PM
Visit my site at http://www.proscan.org/index.htm. Download ProScan and try it out. I hope you will like it.
Bob Aune,
ProScan
Any plans for the 396?
brandon 11-21-2007 6:00 PM
Very cool! Can't wait to get home and try t out. Keep up the great work!
ProScan 11-21-2007 6:12 PM
You bet! It will be coming!
mule1075 11-21-2007 7:53 PM
ok i have a small problem.i dloaded it published the sever all fine.then i tried to get on the client to see if it worked and it will not let me connect.any ideas?
ProScan 11-21-2007 8:00 PM
Have you connected using a previous version of ProScan?
Did the Server actually started or was there a msg like "Port In Use"?
Is the Port number on the client correct?
What msg , if any on the client side?
If the router port fowarding setup correctly?
Do you have any type of software firewall on?
mule1075 11-21-2007 8:13 PM
no i dloaded the new verision of the server.and i dloaded the client also.the server did start and the port is open.on the client side it saying server not responding (5).no firewall on.no router
ProScan 11-21-2007 8:22 PM
try http://canyouseeme.org/ and see if that sees your server.
ka3jjz 11-21-2007 8:35 PM
I'm sure you've heard this before, but hopefully you will add connecting to the RRDB among your list of import options. The specifications can be downloaded from the web service article in the wiki (it's in the right corner as soon as you bring it up)
73s and GL with the new version...Mike
ProScan 11-21-2007 8:40 PM
that’s near the top of my To-Do List
mule1075 11-21-2007 8:46 PM
ok will do.i will let you know more than likely tomorrow evening or friday morning.i tell you what it looks good cant wait to get it working right.
mule1075 11-21-2007 9:43 PM
ok i could not sleep.it sees the server.and still no go.
jobes 11-22-2007 12:54 AM
I've followed this for awhile and it looks so sweet. I hope it makes it to the BCT15 eventully. Plaseeeeee
ProScan 11-22-2007 10:52 AM
Adam, I think I know what's going on. You may have downloaded the Free ProScan Client which as of yesterday was not BC 996 compatible. I recompiled it and it is now BC 996 compatible. Try the new version 2.0.1 or just use the full version as the client. Hope this is the problem.
mule1075 11-22-2007 12:18 PM
that was it all good now.thanks alot
NoRide 11-22-2007 12:21 PM
Yeah. I'd be interested myself. ;)
wjf 11-22-2007 2:48 PM
Good, because that Butel crap that everyone goes ga-ga over is a piece of garbage.
webstar22 11-25-2007 8:03 PM
Bob Aune,
ProScan
What changes were made to the software in the new version. the website lists nothing.
ka3jjz 11-25-2007 8:05 PM
Clear your browser cache - you're probably picking up an old version of the page. The 996 support is totally new.
73s Mike
webstar22 11-25-2007 9:01 PM
thats it just 996 support???? Still not worth buying it then.
