Go Back   The RadioReference.com Forums > Computer Aided Monitoring and Programming > Scanner Programming Software
Scanner Programming Software - This is the place to discuss third party scanner programming and control software.
  #2041 (permalink)
Old 02-06-2016, 2:51 PM
mule1075's Avatar
Are you copying and pasting? If yes stop doing that and type it in manually.
Sent from my Z750C using Tapatalk
Uniden BCD536HPx2/250D Motorola HT1000/GM360
  #2042 (permalink)
Old 02-06-2016, 4:20 PM
No I am typing it manually using the dashes in between the numbers. And I saved the name I used to register it and I'm putting it in exactly as I typed with comas and cap letters.
  #2043 (permalink)
Old 02-07-2016, 9:32 PM
ProScan's Avatar
I tested your Reg Name and it works here. BTW any licensing issue (if any) should be handled by email. No dashes are contained in the Reg Name or Key. Look at your receipt again and enter in the Reg Name and Key exactly as shown.
  #2044 (permalink)
Old 02-07-2016, 9:51 PM
Thanks I'm guessing I am missing a email or something I have only the email receipt from paypal. Also I have emailed the support regarding this issue just thought here was faster and didn't wanna tie things up if I did something stupid or put it in wrong way.
  #2045 (permalink)
Old 02-07-2016, 10:39 PM
ProScan's Avatar
I never received an email. Send again to support@proscan.org and I'll send the receipt.. You should of received an email receipt automatically when purchased.
  #2046 (permalink)
Old 02-08-2016, 5:09 AM
I have resent my email and attached what I have received
  #2047 (permalink)
Old 02-08-2016, 8:35 AM
ProScan's Avatar
I still didn't get an email. Double check you are sending to support@proscan.org
  #2048 (permalink)
Old 02-08-2016, 10:16 AM
I checked and that is the address I sent it to I just tried to send you another message with the subject test. Maybe it went to your spam folder
  #2049 (permalink)
Old 02-09-2016, 8:57 AM
I too am missing the email with the product key, only received from paypal, support email sent
  #2050 (permalink)
Old 02-09-2016, 10:33 AM
ProScan's Avatar
I believe you did receive the receipt with the key because you did activate it. If I'm wrong email me again.
  #2051 (permalink)
Old 02-09-2016, 10:41 AM
My mistake, it went to spam, all is well, Thank you!
  #2052 (permalink)
Old 02-09-2016, 11:29 AM
Yea when I got your email it had the info I needed thank you
  #2053 (permalink)
Old 02-17-2016, 1:29 PM
TedRHayes's Avatar
Default Disconnect between URL Set Up for Comm Port and Source Client
I am running ProScan 10.0. Recently upgraded to Windows 10 on my computer. I discovered that the ip address used in the Source Client URL and the Comm Port URL Setup are not linked (more that just the /au:scanner.au).
I found this out the hard way. The ip on Comm Port was 192.168.1.22 and the ip on Source Client was 192.168.1.122.
Not sure if the disconnect between the two locations is required by the use of multiple BCD536HP or the two locations could be linked.
Thanks,
Ted
  #2054 (permalink)
Old 02-17-2016, 2:51 PM
Magpie's Avatar
ProScan Version 10.0 Released 01/27/16. Note that version skipped to 10.0 from 8.9
Snip
ProScan is the most powerful and feature rich scanner software in this world.
Just wanted to let you know that v.10 is great. Another "best one so far" to me Thank you Bob.
Henk aka Magpie
Diamond D-777 - Diamond X-50N | 5 x BCT15X - 1 x UBC780XLT | SSE Jim-HPF-0706a - CCW Multicoupler | Proscan 12.3 | Espresso
  #2055 (permalink)
Old 02-21-2016, 6:40 AM
Is there a way to have ProScan 10.0 record just one system while scanning multiple systems? I want to have just MPSCS to record, but not any of my local systems.
I have a BCD536HP.
  #2056 (permalink)
Old 02-22-2016, 7:13 PM
BIODTL1997's Avatar
I'm having issues getting audio via WiFi from a 536HP. I saw this was brought up somewhere around the 85th page of this thread but did not see any resolution. Please help, thanks!!
"TCP Not Connected" is intermittent. "UDP Not Connected" is constant. And I notice that there is no assigned UDP port. Proscan ver is 10
  #2057 (permalink)
Old 02-22-2016, 8:23 PM
ProScan's Avatar
The first thing I notices is the URL is missing the " au:scanner.au ". See the usage directly below the URL box.
  #2058 (permalink)
Old 02-22-2016, 8:53 PM
BIODTL1997's Avatar
Thanks. That has been added with no change in status.
  #2059 (permalink)
Old 02-22-2016, 9:37 PM
ProScan's Avatar
I would power cycle the scanner and verify the scanner IP address is the same entered in ProScan? Is the data side working indicated by the virtual display coming to life. Perhaps check that the Wi-Fi dongle has the latest firmware.
  #2060 (permalink)
Old 02-22-2016, 10:07 PM
BIODTL1997's Avatar
Numerous power cycles have been performed, IP is correct, display data is functioning, all firmware at latest revision, windows firewall off.
Tags
bc785d with proscan 6.6, logging, proscan, sleep, windows
