Go Back   The RadioReference.com Forums > Computer Aided Monitoring and Programming > Scanner Programming Software
Scanner Programming Software - This is the place to discuss third party scanner programming and control software.
  #2921 (permalink)
Old 07-28-2017, 3:23 PM
ProScan's Avatar
Originally Posted by plaws View Post
So I'm really hoping Proscan has added full BCDx36HP support so I can use One Ring To Rule Them All.
Anyone? Bueller?
If you're asking me. Any request that takes more than 10 minutes to do should be by email. That way I can organize, prioritize, ask questions, and send out test files. Perhaps if your request was initially via email, it would of been done already but other request would not of been done.
Some want to be vocal and apply public pressure, I don't work good under pressure and tend to go on to other things. When anyone makes a request via email without the drama or commentary, it goes higher on the priority list whether I like it or not.
  #2922 (permalink)
Old 07-29-2017, 1:39 PM
Default Proscan 12.3 Installation Error
Greetings, while updating from Pro Scan 12.2 I encountered the following error message. Using windows explorer, there is no Proscan.exe file in the Program File (x86) folder. Using ABORT shows rolling back changes but Pro Scan no longer executes. A great app that I have been using for several years is dead in the water so any help is appreciated.
Regards,
Name:  PRO SCAN 12.3.jpg
  #2923 (permalink)
Old 07-29-2017, 1:55 PM
Default RESOLVED -Pro Scan 12.3 Installation Error
Installation error has been resolved.
Regards,
  #2924 (permalink)
Old 07-29-2017, 2:03 PM
plaws's Avatar
You've clearly missed my point, so let me be direct: Does Proscan fully support the BCx36HP radios the way it does with the XTs, P2s, etc? It did not last I checked. That's fine. Has the capability since been added? That's all I want to know.
Peter Laws / N5UWY
I am not anti-social ... OK, a little ... but don't friend me, bro.
  #2925 (permalink)
Old 07-29-2017, 3:03 PM
ProScan's Avatar
Your point wasn't very clear and your question changed.
ProScan supports Favorites editing but not Profiles.
It seems like you already know the answer when you last checked. If anything else, let me know.
  #2926 (permalink)
Old 07-29-2017, 3:28 PM
plaws's Avatar
Thank you.
Peter Laws / N5UWY
  #2927 (permalink)
Old 07-30-2017, 10:27 PM
I wanted to try the proscan SW in the 30 day trial. Every time I try to install and start the program I get a window that says the 30 day trial has expired. This is the first time I tried to install in my computer.
Can someone help so I can see if I want to buy the program.
thanks
  #2928 (permalink)
Old 07-31-2017, 10:36 AM
ProScan's Avatar
thanks
Helped via email.
  #2929 (permalink)
Old 08-12-2017, 10:26 PM
radiochuck's Avatar
I love ProScan. I use it at work and plan in getting another license for home.
I have a weird issue with the latest version, 12.3. When I launch the 'Number Tag Tune' function when ProScan is maximized, the dialog that pops up is halfway off the right side of the screen. Any way to prevent this, so that I don't have to drag the window back in each time? I appreciate the help.
  #2930 (permalink)
Old 08-12-2017, 11:19 PM
ProScan's Avatar
I'll fix it before the next release.
  #2931 (permalink)
Old 08-12-2017, 11:24 PM
radiochuck's Avatar
Thumbs up
Awesome! Thank you.
  #2932 (permalink)
Old 08-13-2017, 3:39 PM
radiochuck's Avatar
Originally Posted by 4436time View Post
These may have been mentioned previously, but:
1. Under the Database --> Quick/Search Keys tab --> Group Quick Keys Status section, a complete listing of all systems do not appear in the dropdown
Same. Ver 12.3.
I also found in a few instances that GQK 9 is showing as "not assigned." I think I saw that someone else had mentioned that.
Thanks!
  #2933 (permalink)
Old 08-13-2017, 4:13 PM
ProScan's Avatar
Same. Ver 12.3.
Thanks!
Download the config from the database to sync up the scanner and ProScan data.
  #2934 (permalink)
Old 08-13-2017, 4:22 PM
radiochuck's Avatar
Worked like a charm. Thank you, ProScan!
  #2935 (permalink)
Old 08-13-2017, 7:16 PM
radiochuck's Avatar
Sorry for all of the basic questions. I really do check the help file and search the message board before I ask.
What is "TONE L/O" for a conventional channel? Obviously something different that the regular "Lockout" function for that channel. Thanks!
  #2936 (permalink)
Old 08-13-2017, 7:56 PM
GTR8000's Avatar
Refer to the following site for the Easier to Read guide for your particular scanner, rather than asking basic questions in this thread.
Mark's Scanners
  #2937 (permalink)
Old 08-13-2017, 7:58 PM
radiochuck's Avatar
I know that site. This seemed to be a software specific question, as I don't recall seeing it on the radio or FreeScan.
  #2938 (permalink)
Old 08-13-2017, 8:00 PM
GTR8000's Avatar
Tone Lockout...
Set Lockout - the scanner does not stop on the channel if the tone/code you select is present. Scroll to 'CTCSS or DCS' and press E/yes. Scroll to the desired tone/code you want locked out.
  #2939 (permalink)
Old 08-13-2017, 8:03 PM
radiochuck's Avatar
You got me. That's an interesting feature. Not sure how I'd use that, but I'm sure there's some useful purpose. Thanks, GTR8000. I appreciate the reply.
  #2940 (permalink)
ProScan's Avatar
All ProScan database parameters are scanner parameters. We don't make them up. GTR8000 beat me to it. I've would of referred you to the Mark's Easier to Read manual too. Yes, you will find it in the scanner in the conventional frequencies area. Set the Audio Type to Analog Only and set the Tone and you should see it.
Tags
bc785d with proscan 6.6, logging, proscan, sleep, windows
