Go Back   The RadioReference.com Forums > Computer Aided Monitoring and Programming > Scanner Programming Software
Scanner Programming Software - This is the place to discuss third party scanner programming and control software.
  #3581 (permalink)
Old 06-09-2018, 1:26 PM
CQ's Avatar
CQ CQ is offline
Originally Posted by ProScan View Post
Correct. Thanks. That way I can send out test files to make sure it gets done right. That being said, Next few versions will be focused on the SDS100.
Yes, please...the tiny fonts in detailed view are killing me.
My nuclear button is much bigger than yours
  #3582 (permalink)
Old 06-14-2018, 3:31 PM
Default No Recorded Audio
I have connected an external soundcard to my laptop running W10. When I fire up PS, I can hear live audio from my BCT15X through the laptop's speakers. I see the levels jumping on the "Record" and the "Audio Control" .
I am recording traffic and it's saving them in the "Record" tab. But when I click on an entry, and press Play, the slider moves but there is no sound. Any ideas?
Joe
Nothing clears the mind like a lack of alternatives!
  #3583 (permalink)
Old 06-14-2018, 3:35 PM
Nevermind my previous post. It is working now!
  #3584 (permalink)
Old 06-16-2018, 9:21 AM
ProScan's Avatar
Default ProScan Version 14.0 With SDS100 Support
What's New In Version 14.0
  • Added - SDS100 Support.
  • Added - Web Server - HTML Head Title text box so the web browser tab or title area will show customized text.
  • Changed - Web Server - Renamed the Title text box to Header.
  • Fixed - BCDX36HP Favorites Editor wasn't center justifying text tags correctly.
  • Fixed - BCDX36HP Favorites Editor Get Clipboard wasn't importing UID's correctly.
  • Fixed - BCDX36HP Favorites Editor RRDB import incorrectly importing P25 Phase II systems as X2-TDMA.
  • Fixed - Get Clipboard was importing text tags in upper case.
  • Fixed - XT scanners Database wasn't exporting site frequencies.
ProScan supports the BCT15, BCT15X, BC250D, BC296D, BR330T, BC346XT, BC346XTC, BCD325P2, BCD396T, BCD396XT, BCD436HP, BCD536HP, BC780XLT, BC785D, BC796D, BCD996T, BCD996XT, BCD996P2, & SDS100 scanners.
ProScan is the most powerful and feature rich scanner software in the world !!!
Made in the USA
Most Popular & Feature-Rich Scanner Software For The Uniden's
ProScan - RadioFeed Home Page
bob@proscan.org
  #3585 (permalink)
Old 06-16-2018, 9:24 AM
mule1075's Avatar
Made in the USA
Thanks Bob. Thank you for your awesome software and thanks for your customer service.
Uniden SDS100/780XLT Motorola HT1000/GM360 Whistler TRX-1
  #3586 (permalink)
Old 06-16-2018, 10:08 AM
scan-pa's Avatar
RRDB Admin
Thank you Bob, your software rocks.
Sent from my SM-G935V using Tapatalk
Peter
Scan-Pa
SC PA RRDB Admin
KC3HIO - HAM
WQXU562 - GMRS Cornwall "600" Rptr.
Admiral - 11m
  #3587 (permalink)
Old 06-16-2018, 11:09 AM
Question SDS100 driver
Apparently lacking appropriate search skills, would one of you please point us to a serial port driver for Windows 7?
  #3588 (permalink)
Old 06-16-2018, 11:11 AM
jonwienke's Avatar
For what device?
Gone camping.
  #3589 (permalink)
Old 06-16-2018, 11:17 AM
For the SDS100. An automated search, nor a manual one, can find the driver. I attempted an internet search, even focusing at the Uniden site, but came up short. Me must be duh, yet here we are.
  #3590 (permalink)
Old 06-16-2018, 11:37 AM
jonwienke's Avatar
I didn't need one to connect to the SDS100 in serial mode. I just plugged it in and it worked.
Gone camping.
  #3591 (permalink)
Old 06-16-2018, 11:46 AM
mancow's Avatar
Wow just updated and have the SDS100 connected. This is badass. Thanks!!!
  #3592 (permalink)
Old 06-16-2018, 11:48 AM
I'm using my second copy on a different computer. One to which I've yet to connect a scanner, only used for remote scanner over IP. I'll try looking for BCD536HP drivers just as a shot in the dark.
  #3593 (permalink)
Old 06-16-2018, 12:03 PM
Well, I found it over here: BCD436HP < UnidenMan4 < TWiki
  #3594 (permalink)
Old 06-16-2018, 12:38 PM
CQ's Avatar
CQ CQ is offline
Default ProScan
Glad it's wider to see more info.
Can it be made to not truncate since you're on a PC and space isn't a limitation?
  #3595 (permalink)
Old 06-16-2018, 12:42 PM
jonwienke's Avatar
Some minor SDS100 display bugs, using profile.cfg for colors:
I have the bottom-left icon set to GPS in my profile. It does not show at all in ProScan.
Scan direction arrow icon is the wrong color.
Gone camping.
  #3596 (permalink)
Old 06-16-2018, 12:55 PM
ProScan's Avatar
The GPS icon is the only one that's not in. Can you do me a favor. Go to the test tab and see what the ASCII values are in that position. Will show like ASC(XYZ) ASC(XYZ).
Regarding the arrow wrong color, Which mode is the scanner in? Simple Conv, Detail Conv, Simple Trunk, Detail Trunk, etc.
In the Sentinel Display Editor, select the same tab as the scanner mode to see if different color.
bob@proscan.org
  #3597 (permalink)
Old 06-16-2018, 1:17 PM
jonwienke's Avatar
ASC 181, 182, 183. 182 appears to be Close Call icon?
Arrow is wrong color in Detail conv & trunk modes. Arrow is the correct color in Simple conv & trunk modes.
When you press the scroll knob down to show volume or squelch bar graph, text and bar colors are wrong, should be white, not the rainbow colors of different icons there otherwise.
Gone camping.
  #3598 (permalink)
Old 06-16-2018, 1:51 PM
ProScan's Avatar
Thanks, Got the GPS icon/text showing. Arrow for detail conv and trunk right colors.
Regarding the vol & squelch text and graph showing different colors, will look at that in a while.
Here is the fix for the arrow wrong color detail conv. and trunk. GPS icon showing.
Unzip and copy the exe file over the original. http://proscan.org/ProScan.zip
bob@proscan.org
  #3599 (permalink)
Old 06-16-2018, 2:24 PM
ProScan's Avatar
Anyone discovered the soft keys on the display are clickable?
bob@proscan.org
  #3600 (permalink)
Old 06-16-2018, 2:28 PM
jonwienke's Avatar
Looks good so far, fixes are working as indicated.
Gone camping.
Tags
bc785d with proscan 6.6, logging, proscan, sleep, windows
