btritch
Ok, Here's one I've never seen before, someone here may have saw it before but I have a scantenna about 40 to 50 feet up in the air, Feeding from it to my shack is LMR 400 Coax, Then it ties into a splitter and runs to my GRE PSR 500 and my PRO 97, My PRO 97 works great as does my PSR 500 UNTIL I hook up my scantenna to them, It will work great on my PRO 97, But it will not work on my PSR 500, It won't stop on the frequencys, But if you turn off the PL tones, It will, However, If you hook it up to the original duck antenna then it works great, What causes this? Is it because the local departments are too close and it's overloading the GRE as sensitive as it is? Should I try the ATTENUATOR and see what happens? Does anyone have any suggestions what it could be or what I can do?
