On my IC-706MK-IIG mounted in my van I tried to use a Comet rubberized dual band antenna (rubber flexible whip) that works just fine with my Kenwood TMD-700 as well as other radios, even with the same mount and coax. The 706 will not work with this antenna, the SWR is atrocious and RX sensitivity is almost non-existent. I was trying to see what was going on and as I removed the PL259 from the radio as soon as the ground disconnected and just the center pin of the PL259 was touching the SO239 center the receiver came alive on a NWS channel.
I tried a few other antennas and found that the radio worked great on 2M with a plain old 1/4 wave NMO whip, same for 440. I found a dual band MaxRad that worked well too.
I used an ohm meter to find that the Comet and a couple other dual band antennas have show a dead short across the center pin and thread on the NMO while the 1/4 wave does not of course. I also checked the continuity of the coax and it was fine.
Is there possibly a short on the antenna jack of the 706 that could cause this or is this normal? I find it weird that the Kenwood (and the IC-2800 that preceeded it) work great with this Comet dual band antenna.
I also tried my Diamond 8900 and it worked fine, and also shows open between the center pin and collar.
The Comet dual band also works great on my BCD996T, even better on VHF than a 1/4 wave.
