I finally moved to an apartment house where i can have outside antennas!!! So, i finally figured out an easy way to mount my mast to the house so now i have my ST-2 and my homemade 2m/70cm dual band Jpole copied off of Arrow Antennas design. The reception is good as far as i can tell. since i haven't tried other antennas for comparison here i can only assume my antennas are working great. I can hit some far away 2 meter repeaters with the jpole so i can only assume its working as good as a ARx2B. My ARx2B and other antennas are in a storage unit. Someday i hope to have a house so i can put out my scanner beam as well on a rotor.
I inspected the ST-2 construction and man it's flimsy for being a sturdier version. I got an idea nobody else talks about. instead of reinforcing it. Why not buy or find some stronger tubing and just rebuild the whole thing or at least the main section? Somebody should start a ST-2 rebuild service. or email the company for this suggestion for a higher quality version. they have higher quality TV antennas and different product lines of different qualities. so why not have a higher quality scanner antennas?
Eric Burris kc0ldt
Eric Burris kc0ldt
