reconrider8
ok i have a rs antenna but it doesnt pick up 800 band very well so i was wondering if i get a T and hook up an 800 mhz antenna would it work with both and help my 800 any
Not wanting to start a war on who is right and who is wrong, the bottom line is that if your only
going to use the antenna for receiving, it really doesn't matter. the mis-match from hooking
two 50 Ohm antennas together only makes it look like a 25 Ohm antenna match. On receive,
this isn't that bad. The frequency band of say VHF and 800 or VHF, UHF and 800 will work
for a scanner antenna.
Now if your asking to transmit on this kluged antenna system, this is a whole different matter.
Don't do it. Go for a triplexer and get the correct match. There are a couple of companies
that make such a unit. Have used them a number of times on mobile command centers
where we have run out of cables going to the roof. You then install a tri band antenna
and use the triplexer to split the antenna to 3 different radios. The triplexer has band pass
filters in it to allow just the range of frequencies they are made for to pass.
Sometimes you just have to buck the normal and go with what us old time communication
engineers have to work with. If you haven't been there and done that, then how can they
say not to do it this way or that way. Any way, go for it and have fun with your scanner.
Jim
If a standard one will not meet your needs then custom diplexers based on Model LH7 can be bought from Tin Lee Electronics here:Take a look here http://www.rfparts.com/diamond/Product_Catalog/plexers.html and see what duplexer or triplexer will cover the ranges you want to monitor. You would have to use some adapters at some point to match up your connectors, but you can see these devices give you some flexibility for properly matching multiple antennas. And agree with Prcguy, you would very likely have some signal phase cancellation problems just using a combiner. If you're gonna do it, do it up right.
this is the one i want to add http://www.radioshack.com/product/i...er/HAM&allCount=24&parentPage=family this is the one i got http://www.radioshack.com/product/i...er/HAM&allCount=24&parentPage=family i didnt see ant duplexer that really covered what i needed
