trimmerj
I use this for monitoring 39mhz. Used a cheap stainless steel mixing bowl and a radioshack 102" and 3/8 mount. Elements were cut down to 5.9 '. The radials are alunimum rods attached to the bowl with electrical lugs. Had an old Radio Shack Mag mount that was used to hang it, mount was scavanged and turned upside down. The set screws hold the top of the whip and a 1/4 " eyebolt is used to connect the rope. I hung it over a tree limb about 60' up and a second rope is used to stabilize the antenna. Probably bugs the neighbors...
