Should I go with comtelco or RS? for mobile
I want an antenna for around 162 - 170 mhz , 450 and 800.
I hear good things about the radio shack mag mount? --Model: 20-032 | Catalog #: 20-032
I also found locally a comtelco A11331B-Z
http://www.comtelcoantennas.com/PDF Datasheets/A11331.pdf which is a little cheaper than the RS.
Anyone have any exper. with the comtelco mobile?
Just want a good all around better soulution to the duck while on the road. Mag mount looks good as I will be using it in two different vehicles. The comtelco I listed seems to target the freq I will use most. I can't find any freq range on the RS
