Per my previous post, I finally got a deal on eBay for $75 for a Garmin GPS 18 PC, which uses DB-9 serial to connect to the Uniden BCT-15 scanner and a cigarette lighter adapter for power from the 12v / 13.8 vDC of a vehicle's auxiliary line through a voltage regulator out to the 5v that the GPS puck expects.
I used "industrial strength" Velcro discs, one adhered to the magnetic underside of the GPS receiver puck and the other to the top of the cowl for the instrument panel -- in other words, hidden underneath the dash top.
However, the BCT-15 doesn't seem to detect satellites right away. Is the dash of the car interfering too much with hearing the GPS signal? Or is there just some setting in the BCT-15 that I need to configure first to recognize it? The Garmin GPS 18 PC definitely outputs the NEMA 0183 coding of GPS information required by the BCT-15.
