Hogger34
Been looking around for a good scanner antenna mount for the front and have had no luck. I'm debating on this mount that I've made but not sure of the position; I like that the antenna will have a clear view but looks a little awkward to me but not sure. What do you think as far as reception? The antenna is an Everhardt tiger scanner antenna which I had mounted on my Nissan Titan. The coax has not been ran until I see how it holds up to daily driving. If it holds up I plan on using a Firestik Fire ring or something similar to get it to my radio. To make this mount work I had to move it forward to line up with existing fender mounting bolts.
