Got a desktop scanner that basically sits on a desk and doesn't use anything other than a rubber duck or other simple spike?
If you power it with a wall-wart, you can make up the missing groundplane for VHF by choking the power lead.
A two-pack of RS #273-104 are ideal for this. Choke it at the output of the wall-wart. Then on your favorite band, choke the power lead a 1/4 wave (234/f mHz) from the end of the connector. I usually cut it about 2 inches shorter since the handheld has a small amount of groundplane internally.
So for my activities centered on 127 mhz, I just choke it at about 20 inches from the end of the connector. The spec-sheet included with the 273-104 make it easy to figure out the wind.
If you have enough of a lead, you can experiment by laying the power lead down horizontally, or just leave it hanging down from the back of the desk vertically.
Obviously this is just a little quickie type project, but is a win-win as you clean up the noise from the wall wart and put the power lead to better use.
With an external antenna, I wouldn't try to choke the power lead at the 1/4 wave point - just at both ends of the power lead.
