I searched this forum for info on the Phantom Elite and found some old threads. I thought I'd share my comments on it.
I picked one up the other day. Its very small and I love the stealth metallic-black color. The pictures I saw made it seem like a chunk of plastic. It installed in seconds on my Dodge Durango. (I use a BCT-15 scanner.)
(The base of the Elite is spring-hinged so you press down and screw on the NMO. Then you just turn the "wing" clockwise so that the trailing edge is pointing toward the front. It's a very solid design.)
I was using a Larson 866mhz NMO for my trunk scanning, but I had always been curious about the Phantom and Phantom Elite. I seem to always find "something" to hit my antennas with so I wanted to find a smaller solution. The Larson runs about 12" (with spring) and the Phantom Elite is barely 4" high.
In this area we have several valleys that dip behind hillsides - small shopping malls, etc. I was in an area where reception is very sketchy at best. Even on the Larsen the reception was scratchy - but I could still hear units, dispatch, etc. The Phantom Elite wouldn't even get the control channel(s).
That being said, as I soon as I was in the open, everything was good and strong. I didn't have a lot of time to see how it works in the surrounding areas, but so far I'm pleased. Sure it would be nice if it were 'perfect' but I needed a small replacement, so is a good compromise.
I think if you are using this antenna in a urban (flat) environment, I think you'll be fine. If your area is known to have a few radio 'black holes' then you'll likely suffer degraded performance.
The price point is not terrible either. If you are looking for a concealed antenna then this is it.
