AreThree
After being out of scanning as a hobby for many years, and now finally getting the itch to get back into it, I have decided to purchase a BCD396XT Scanner. I have had good luck with Uniden products in the past, and that was one of the deciding factors in which one to get (rather than the GRE PSR-500 or the RadioShack PRO-106).
That being said, I am now also in the position to have an antenna on the roof for the first time. My main office, and where I would be mainly listening and working with the scanner, is in the basement, surrounded by PCs and other RF noisy devices. I would like to put an antenna on the roof and run some cable down to the basement.
I was looking at getting the WBD-40 Discone Base Antenna from ScannerMaster.com and wanted to ask for your feedback and any tips that you all might have (like is this a good idea at all, or if there is a better solution, or better antenna). Also, I understand that there is going to be some differences in cabling and connections to the scanner, and was wondering if you might be able to help me understand the best way to do this.
Thank you so very much, and I look forward to hearing what your collective wisdom has to say.
