I find your statement about no luck with glass mount antennas to be some what foreign. I have
for many years used glass mounted antennas with great success. Matter of fact I have done
a number of tests to see if the glass mount or mag mount was better. The results have shown
that a properly installed glass mount antenna will perform just as well as a mag mount. However,
I will point out that the testing was don on UHF and 800 only. I don't believe that VHF glass
mounted antennas have enough coupling to function properly.
Along with my above comments, I will point out that the glass mount antennas can not be
used on glass that has internal tinting. Most of this tinting is from metallic particles and
effects the glass mount coupling. You also can't mount the coupling units over the wires
on or in the glass used for heating the window to remove frost.
Jim
Never had any luck with on-glass antennas - period.
Is it a mobile radio or handheld? If it's mobile, why not a magnet mount on the trunk (or lip mount) - or a permanent NMO mount. A black 1/4 wave NMO whip is pretty stealthy.
