I was planning to do an install and wanting to make sure this would work. I am planning on buying:
Larsen NMO Tri-Band from TESSCO Item # 427126
Larsen Trunk mount from TESSCO, NMO, UHF/M Item # 90866
Since the trunk mount say UHF/M, will i need to crimp the connector to the cable or will it already be pre-made? I don't have crimpers to crimp the connector on the wire. I was planning just using an adapter to go from uhf/f to sma/m. I realize going through an adapter there will be some loss. Could someone make sure I am going in the right direction?
