How does this antenna compare to the Radio Shack 800Mhz? I got one awhile ago and i have noticed a improvement over the stock antenna on my 396T and wonder if this would have better reception.
I have both, and use both interchangeable on my PSR-500 and Pro 162.
Here's a non-scientific review by band.
VHF LO: Never listen there. I would assume the Diamond is better, because the 800MHz doesn't pick up much on higher VHF.
VHF-Hi: The Diamond wins here hands down. Picks up VHF-hi much better than the stock antenna. the 800MHz catches a strong VHF signal every now and then. but it misses most.
UHF: The 800MhZ actually performs quite well in the 450-480MhZ range I listen to most often. The Diamond may pick up fainter signals a little bit better, but in terms of signal strength, I've found they're nearly equal.
800MhZ: The Diamond performs extremely well on 800MhZ, both conventional and trunking. I would say that the 800Mhz antenna is perhaps a little bit better in picking signals from further away, and the signal strength is a little better on received signsla (three bars versus 1-2 bars).
If you could only afford one antenna, I'd recommend the Diamond. But, of course, none of us scanner hobbyists ever gets one of anything!
Suzie
