There is a reasonable chance that you will be able to hear some of the higher profile VHF systems at 60 miles. Your home would need to be on a hill or at least have good elevation above mean sea level with no intervening mountains, hills, etc between you and the city. As for 450 mHz systems, they will prove to be more of a challenge with regular reception somewhat iffy unless there is some form of enhance propagation taking place.
At 800 mHz and above, we are talking basically line-of-sight with relatively little or no signal refraction taking place at the visual horizon of the antenna system like would occur on the lower bands. Here's a rough rule of thumb you can use to crudely guesstimate system coverage. Find a line-of-sight calculator and determine LOS distances with typical antenna hights of , say 30 feet for your end and 300 feet for the system end. Next multiply the answer by 1.5 to get VHF radio range, 1.2 for UHF radio range and 1.0 for 800 mHz radio range. This is not cutting edge accurate, but will give you and educated guess of what to expect
