I have a Radio Shack Pro-95 scanner.
Houston Police 400 mhz conventional frequencies pick up flawlessly inside my house no matter where I am. However, 800 mhz trunked frequencies for the sherrif and constable's rarely pick up indoors, and usually if I set my scanner in a window. Outdoors, the 800 mhz reception is tolerable but could be much better.
I'm sure there are a myraid of technical possibilities for this issue, and would like to read your opinions. I'm sure an antenna on the roof would help greatly. But, just wonder why Houston PD (400mhz) works so well indoors and 800 mhz doesn't without an outdoor antenna.
I've tried the rubber ducky, 800 mhz rubber ducky, and their long metal antenna. The metal antenna seems to grab the 800 mhz frequencies a little better.
