dennisjamesnc
I am trying to trim a mobile antenna to be tuned to the specific 800 MHz channels I listen to the most. My antenna holder allows about ½ inch of the antenna to slide into the holder. See attached picture of the holder.
My question is; In order to trim this antenna as accurately as possible, do I make any allowance for the portion of the antenna that is inside the holder or do I measure from the top of the holder ?
e.g. I will use rounded numbers for simplicity sake. Let’s assume for a second that the antenna needs to be 13.5 inches to be tuned exactly. The antenna holder receives ½ inch of the antenna whip. Do I cut the antenna to 14 inches, 13.5 inches or some value between 13.5 and 14 inches ?
Thanks,
Dennis
Thanks,
Dennis
